Configures the loop protect event threshold.
stpd_name | Specifies an STPD name on the switch. |
threshold | Sets the number of loop protect events that must be received before disabling the port. The valid range is 1–10. |
none | Disables the loop protect threshold. The port will not remain enabled even if loop protect events are received. |
By default, the loop protect threshold is enabled and set to three loop protect events.
If the loop protect event threshold disables a port, you must enable the port manually.
The following example configures the loop protect event threshold to five events.
configure stpd r1 loop-protect event-threshold 5
This command was first available in ExtremeXOS 15.7.1.
